hi there hope someone can help me i bought a bush devil of ebay since i got it theres been a problem with the truck not pulling away fast enough it seems to be slipping so i changed the gearbox gears,drive shafts,drive cups,put on a esp,also put on a new motor(25)speed but this has not helped can any one help me please many thanks porky
If thats the problem, glue the tyres to the rims with super glue.
Or try putting rubberbands in the grooves where the tyres sit. This can work as a non-permanent solution.
Either a rear wheel hex has worn out, or the rims are spinning in the tyres.
It might seem obvious but many people forget the rims can spin in the tyres :D
thanks for your help what i did first was put rubber bands around first 'ITWORKED' so now i will glue like you said thank you for your help
THANK FOR YOUR ADVICE PUT RUBBER BANDS AROUND FIRST TO SEE IF IT WORKED AND IT DOES SO I WILL NOW SUPERGLUE THEM IN PLACE THANKS ONCE AGAIN
[/quote
IT WORKED NOW IT WONT STOP WHEELYING THANKS FOR YOUR HELP NOW I WILL PUT SUPER GLUE IN THEM THANKS AGAIN
I found the Bush Devil's rear bed has such an overhang beyond the back wheels, the lexan gets damaged very easily when it flips backwards and drags itself along the ground. You may want to keep an eye on that.
ok i will make a metal skid plate for that thanks porky
