hi,
the front propeller shafts are the same.
the rear hilux/blazer propeller shafts are a bit longer as the bruiser/mounty shafts.
nope, they are too short
Hi Jim , thats strange,I have 2 hilux / Blazer sets and a set of Bruiser ones , and the rear prop of the Hilux is longer than the rear prop from the Bruiser? . here is a pic - the 2 top shafts are from my Hilux / Blazers and the bottom one is from my Bruiser all props are fully compressed to their shortest lengths for comparison .The Bruiser one is a lot shorter.I asked the question because i wondered if the Hilux shaft would be too long - now i'm confused :)
hi,
Thanks Thomas .That clears it up. By the way - would you have a good Bruiser rear prop shaft for sale? :)
  • 1 year later...
Can someone please tell me the lengths of the Bruiser / Mountaineer prop'shafts (front and rear)?
I'm trying to figure out whether I have Hilux / Blazer ones or Bruiser / Mounty ones?
Mine are ;-
Front = 76.9mm compressed
84.3mm extended
Rear = 134.9mm compressed
142.8mm extended
Help would be great
Cheers,
Alistair G.
Mine are ;-
84.3mm extended
142.8mm extended
Help would be great
Cheers,
Alistair G.
checked out my spares boxes and from my Mounty / Bruiser box I have these sizes :-
rear shaft = 102 compressed
110 extended
pretty sure all front shafts are the same ,but mine measures :-
52 comp
60 ext
from my Hilux / Blazer box :-
rear :- 110 comp
118 ext
I would assume you have measured yours with the other UJ's attatched this would account for the differences to mine ,If you take the UJ's off yours then check against my sizes that should give you your answer :)
110 extended
52 comp
60 ext
rear :- 110 comp
118 ext
Ah yes I measured with the 2 UJ's attached. Taking off 1 UJ to just leave 1 on the shaft (the unremovable one being the only one remaining), gives ;-
Rear :- 110.2mm compressed
118.1mm extended
Front :- 51.04mm compressed
58.8mm extended
Looks like I have Hilux RA1028 shafts. Cool. Just what I wanted actually. Very odd since they were advertised on the auction as being off a Bruiser / Mountaineer.
Unless someone with a Hilux can tell me what the length of their prop. shafts is? Pretty please? LOL.
Many Thanks Kev, it's appreciated.
Cheers,
Alistair G.
