I've got a tt-01 but I think there's something wrong with the cristal or the receiver because
when I start op my car i hear a bleep sound, even if my steeringwheel is on it bleeps now
i don't know whats wrong my receiver, my cristal or my stearingwheel ?
is there a way to check it ???
thanx
Driftking_V8(marcsnak3y)
thanx
I know with the TEU101BK if you turn on the ESC without having your radio/transmitter on it will start beeping at you. Have you tried a different receiver, or the reciever alone (use the battery pack, most futaba's come with one). Sounds like a fault with the ESC or your reciever is malfunctioning if you indeed have the TEU101BK.
Any more info you can give will help.
yah i've got that one the TEU a red light is flashing and beeping anD my transmitter is from Futuba
Is it fitted with an electronic speed control? Is the ESC set-up correctly according to it's instructions?
yeah it is but first he did it great and then on am moment he felled just out and now he doesn't work i thought maybe the receiver is broken
but when i turn im on the servo moves so the receiver has to work but i can't get connection between receiver and steerwheel
How is it plugged in to the reciever? what plug to what channel?
Press and hold the button on the ESC and the power it on and see what happens.
But the servos work because if i turn them on they react but it doesn't react with my steeringwheel
If your steering doesnt work from the transmitter i would say your reciever is broken, that would also explain why the TEU101BK is beeping since it thinks that it is on without a transmitter being on, the beeping is a safety feature to remind you to turn on your transmitter or remind you that you forgot to turn the car off.
no he does work again !!!!!
new crystal in it !!!
thnx for helpin me out guys (*)
