driftking_v8 0 Posted November 13, 2007 I've got a tt-01 but I think there's something wrong with the cristal or the receiver because when I start op my car i hear a bleep sound, even if my steeringwheel is on it bleeps now i don't know whats wrong my receiver, my cristal or my stearingwheel ? is there a way to check it ??? thanx Driftking_V8(marcsnak3y) Share this post Link to post Share on other sites
PSXBatou 2 Posted November 13, 2007 I've got a tt-01 but I think there's something wrong with the cristal or the receiver becausewhen I start op my car i hear a bleep sound, even if my steeringwheel is on it bleeps now i don't know whats wrong my receiver, my cristal or my stearingwheel ? is there a way to check it ??? thanx Driftking_V8(marcsnak3y) I know with the TEU101BK if you turn on the ESC without having your radio/transmitter on it will start beeping at you. Have you tried a different receiver, or the reciever alone (use the battery pack, most futaba's come with one). Sounds like a fault with the ESC or your reciever is malfunctioning if you indeed have the TEU101BK. Any more info you can give will help. Share this post Link to post Share on other sites
m.l.field 0 Posted November 13, 2007 Is it fitted with an electronic speed control? Is the ESC set-up correctly according to it's instructions? Share this post Link to post Share on other sites
driftking_v8 0 Posted November 13, 2007 I know with the TEU101BK if you turn on the ESC without having your radio/transmitter on it will start beeping at you. Have you tried a different receiver, or the reciever alone (use the battery pack, most futaba's come with one). Sounds like a fault with the ESC or your reciever is malfunctioning if you indeed have the TEU101BK.Any more info you can give will help. yah i've got that one the TEU a red light is flashing and beeping anD my transmitter is from Futuba Share this post Link to post Share on other sites
driftking_v8 0 Posted November 13, 2007 Is it fitted with an electronic speed control? Is the ESC set-up correctly according to it's instructions? yeah it is but first he did it great and then on am moment he felled just out and now he doesn't work i thought maybe the receiver is broken but when i turn im on the servo moves so the receiver has to work but i can't get connection between receiver and steerwheel Share this post Link to post Share on other sites
PSXBatou 2 Posted November 13, 2007 yeah it is but first he did it great and then on am moment he felled just out and now he doesn't work i thought maybe the receiver is broken but when i turn im on the servo moves so the receiver has to work but i can't get connection between receiver and steerwheel How is it plugged in to the reciever? what plug to what channel? Press and hold the button on the ESC and the power it on and see what happens. Share this post Link to post Share on other sites
driftking_v8 0 Posted November 13, 2007 How is it plugged in to the reciever? what plug to what channel?Press and hold the button on the ESC and the power it on and see what happens. ok im now gonna try it Share this post Link to post Share on other sites
driftking_v8 0 Posted November 13, 2007 ok im now gonna try it it beeps twice, the wheels react and then it beeps normally and in channel 1 i,ve got th servo and channel 2 the esc and in the last one ive got the accu Share this post Link to post Share on other sites
driftking_v8 0 Posted November 13, 2007 if I hold it in and turn it on than only the lights go on but no sound Share this post Link to post Share on other sites
driftking_v8 0 Posted November 14, 2007 if I hold it in and turn it on than only the lights go on but no sound But the servos work because if i turn them on they react but it doesn't react with my steeringwheel Share this post Link to post Share on other sites
PSXBatou 2 Posted November 14, 2007 But the servos work because if i turn them on they react but it doesn't react with my steeringwheel If your steering doesnt work from the transmitter i would say your reciever is broken, that would also explain why the TEU101BK is beeping since it thinks that it is on without a transmitter being on, the beeping is a safety feature to remind you to turn on your transmitter or remind you that you forgot to turn the car off. Share this post Link to post Share on other sites
driftking_v8 0 Posted November 15, 2007 If your steering doesnt work from the transmitter i would say your reciever is broken, that would also explain why the TEU101BK is beeping since it thinks that it is on without a transmitter being on, the beeping is a safety feature to remind you to turn on your transmitter or remind you that you forgot to turn the car off. no he does work again !!!!! new crystal in it !!! thnx for helpin me out guys (*) Share this post Link to post Share on other sites
