I thought they are to long in the wheel base (the Escorts that is)
The escort fits under the TT01 .
You do know the escorts are MK1 & MK2 escorts , Not the cosworth escort . :)
This week I received a set of nip Escort Cosworth Wheels for my project courtesy of Percymon. :)
And a very muddy MudBlaster!
A bagfull of 10 2.4ghz receivers. :)
9 Orange 2.4ghz 6 channel receivers and one 4channel parkflyer receiver for use with my Spectrum DX6i
Photo for size with an Futaba 40am receiver
Some Mtroniks esc's, some Turnigy Hardcase Lipo's, some Turnigy lipo's for my Caster 1/18 buggy, some other 1/18 spares, Blitzer Beetle decals.
:) Are you sure ?. ;)
A bit work to do there . Nice with the nerf bars . :)
I have the other parts didn't include it on the pics got excited.. :D
Body, deck all sorts of parts.. :D
I have finally got a 3 speed :) Til i got it .
Needs alot of stuff to get to be in working condition .
Screws , rubbers/ grommets , universal joints ,
chassis ? , tyres , body , battery/servo tray/box ,
manual & more . :)
Not sure if it was a good buy now ;)
Found more wrong with it Axel tubes cut on rear diff .
I knew about the body , servo box & battery box .
Today I got 10.5m of stainless steel 3mm tube in 260mm lengths. Also got a bipe bender for the tube. The tubing is to make the hoops for the canvas on my ta01 land rover.
Packing the tube with fine grained sand will help to stop the tube crushing as you bend it
Yer I tried that before. It works ish, but you can not get two angles the same and you can not get the bend to start exactly where you want it.
Pack the sand as tight as possible.
What bender are you using?
When bending you need to leave 'green' on the ends, a bit extra material that can be trimmed off afterwards to get the precise length.
You also need to do some calculations and mark out the centre of the bends, allow for the radius of the die etc.
Bit hard to explain here. ;)
Google might be your friend.
I think with a little practice I will get there. This is bender http://cgi.ebay.co.uk/QUALITY-MINI-BRAKE-P...=item415502804a
Thanks for your coments.
The parts I ordered to restore my Pumpkin have arrived. :angry:
Looks like the hole thing , Must have been not much to restore :o Alot of parts . <_<
