Nicadraus 6201 Posted July 8, 2019 On 7/6/2019 at 12:26 AM, Juls1 said: Is it just me or does everything in those bags look like GPM parts with a Xtra Speed label stapled on? They look similar but they're different from each other's brand. The steering for example in the Xtra Speed is just an aluminum version of the stock and has no bearings at all which is a let down actually. I have the GPM set which was designed better with bearings but is a let down as well. Now I have to get either a Year Racing or Hot Racing steering set which I heard, both are excellent for the CC-01 but the HR being a little better. Share this post Link to post Share on other sites
nowinaminute 2815 Posted July 8, 2019 8 hours ago, nowinaminute said: Let's see what a £14 8000mah hard case lipo is like! In fairness, it's made by fullymax and they seem to be quite good budget batteries. I think all the Overlander lipos are currently manufactured by Fullymax and they aren't bad. If you don't hear from me again, assume it wasn't very good. Well, it just took 4200mah on its first charge, starting from 3.85v per cell so the 8000mah capacity seems feasible. The only thing I find a little disconcerting is that the bullet sockets pass right the way through the pack. This is apparently so you can connect multiple packs in series or parallel which makes sense but they usually come with little bungs to put on the underside but this pack didn't come with any. I'm usually the person to speak out against lipo paranoia but in this instance, even with the cables connected, there still an exposed + and - on the underside that are just waiting for my fat fingers to short them out! I've just put a little tape over the bottom for now but I'll see if I can find some suitable bungs. 1 Share this post Link to post Share on other sites
berman 5315 Posted July 8, 2019 Postie brought me some new rear Monster Jam tyres for my Stampede as the old ones are getting a bit bald. 2 Share this post Link to post Share on other sites
Juls1 1661 Posted July 9, 2019 15 hours ago, Nicadraus said: I have the GPM set which was designed better with bearings but is a let down as well. Now I have to get either a Year Racing or Hot Racing steering set which I heard, both are excellent for the CC-01 but the HR being a little better. I’ve had a number of GPM parts in the past including alloy steering sets for CC01, they are pretty terrible, the yeah racing steering set for CC01 plainly and simply works. Just a shame it only comes in blue. Share this post Link to post Share on other sites
a.w.k. 665 Posted July 9, 2019 found locally....... they are still out there NIB...... really happy 12 1 Share this post Link to post Share on other sites
Nicadraus 6201 Posted July 9, 2019 8 hours ago, Juls1 said: I’ve had a number of GPM parts in the past including alloy steering sets for CC01, they are pretty terrible, the yeah racing steering set for CC01 plainly and simply works. Just a shame it only comes in blue. I ordered the HR set which will arrive in a couple of days. I will do a small review about it once I have installed and tested it. Share this post Link to post Share on other sites
nowinaminute 2815 Posted July 9, 2019 23 hours ago, nowinaminute said: Well, it just took 4200mah on its first charge, starting from 3.85v per cell so the 8000mah capacity seems feasible. The only thing I find a little disconcerting is that the bullet sockets pass right the way through the pack. This is apparently so you can connect multiple packs in series or parallel which makes sense but they usually come with little bungs to put on the underside but this pack didn't come with any. I'm usually the person to speak out against lipo paranoia but in this instance, even with the cables connected, there still an exposed + and - on the underside that are just waiting for my fat fingers to short them out! I've just put a little tape over the bottom for now but I'll see if I can find some suitable bungs. Well I have to say I'm incredibly impressed on first impressions, the pack has huge punch! Probably because it's a 2s2p pack so it's essentially 2 pairs of 4000mah packs. My Slash 4x4 with a 3900KV really rips off the line with this pack even more than usual. I found the voltage sagged a lot less than normal packs too, so much so that I will have to set my voltage alarm differently. I usually set it to trigger around 3.2-3.3v under load and get 3.5-3.7 resting voltage but with this pack, I set it at 3.3v and it only rose to 3.4v at rest! I always try to avoid going that low but I'm used to a much bigger recovery at rest. This pack sags so little under load that the amount of recovery is much less too! I got a massive 7400mah into the pack charging it from 3.4v so I think the 8000mah claim is very realistic! I should be able to get 6400mah out of the pack without straying past the recommended 80% limit. I'll have to use it a bit more to get a better overall impression but so far this pack seems to be superb. Easily the punchiest 7.4v lipo I have ever owned, great voltage stability and tons of capacity! Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted July 9, 2019 Some on road springs courtesy of sounds advice from @svenb, and some touring car toe in blocks courtesy of the invaluable information @qatmix put on thercracer.com. Thanks chaps! Just need my TA06 to turn up now! Share this post Link to post Share on other sites
jupitertwo 1484 Posted July 9, 2019 After making a hash of my Jimny shell some months ago, my MF01X has remained unfinished while I pondered what to do. Happens across one of these, so I thought I’d I’ve it a try I didn’t realise it came pre drilled, so hopefully things can be made to match up, otherwise some strategic sticker placement will be required Share this post Link to post Share on other sites
Grumpy pants 4485 Posted July 10, 2019 Quite a decent haul this lot. Unpacked, but that will be it for the next week or two, getting married tomorrow so quite a busy week 😉 2 modified FAV’s, Handset, spares and another set of wheels to move along 😂 4 Share this post Link to post Share on other sites
max69vk 708 Posted July 11, 2019 One of the better bits about coming home from holiday, is opening all of the parcels you ordered while away! 3 Share this post Link to post Share on other sites
dave.723 132 Posted July 11, 2019 To be unpacked ... 5 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted July 11, 2019 Forget the package, I love the bike! 1 Share this post Link to post Share on other sites
dave.723 132 Posted July 11, 2019 ... And unpacked. At last I got a KBF. Need to get it ready for vacation. 4 Share this post Link to post Share on other sites
jupitertwo 1484 Posted July 11, 2019 An Evo X body (already cut and drying) and 4 cheap servos as recommended here: Share this post Link to post Share on other sites
jupitertwo 1484 Posted July 11, 2019 An Evo X body (already cut and drying) and 4 cheap servos as recommended here: 1 Share this post Link to post Share on other sites
nbTMM 433 Posted July 12, 2019 Got this lot to transplant my 5100kv/3S on-road TT02 drivetrain into. Meanwhile the on-road car will be converted back into a low power countersteer drift car. Neo Scorcher (the best looking TT02B, imho), YR universal shafts + cups, High speed gear set, YR adjustable motor mount, RW Racing 48dp gears, and an Eagle Racing propshaft and steel joints that I already had sitting around unused. 5 Share this post Link to post Share on other sites
jupitertwo 1484 Posted July 12, 2019 10 hours ago, nbTMM said: Got this lot to transplant my 5100kv/3S on-road TT02 drivetrain into. Meanwhile the on-road car will be converted back into a low power countersteer drift car. Neo Scorcher (the best looking TT02B, imho), YR universal shafts + cups, High speed gear set, YR adjustable motor mount, RW Racing 48dp gears, and an Eagle Racing propshaft and steel joints that I already had sitting around unused. Looks like a lot of fun, I got a lot of gearbox issues when putting big motors / 3s in Tt02b buggies. Steel diffs are usually the shout, but I never cured it. If you get this running sweetly please post with what you did! Share this post Link to post Share on other sites
nbTMM 433 Posted July 13, 2019 2 hours ago, jupitertwo said: Looks like a lot of fun, I got a lot of gearbox issues when putting big motors / 3s in Tt02b buggies. Steel diffs are usually the shout, but I never cured it. If you get this running sweetly please post with what you did! Will certainly do. The only problem I've had with my road car was the motor pinion skipping but that was with 64dp gears and once I made the mesh tighter than I would usually set it, it stopped being a problem. The bigger buggy wheels and higher FDR will certainly up the ante by increasing the torque that the diffs handle. Standard diffs are glass reinforced nylon which should be plenty strong enough. I think the problem people have is the diff pinion gear skipping due to slop between it and the propeller joint - I add shims and kapton tape over the flats of the joint to remove all slop so that's probably why I don't have issues yet. The unknown for me will be if the smaller spider gears inside the diff start skipping. Share this post Link to post Share on other sites
J@mes 2326 Posted July 13, 2019 Some paint, filler and a Clod bag D in my post yesterday I took the after market rubber flared arches off my Clod & have a lot of tiny holes to fill! Share this post Link to post Share on other sites
novicelad 787 Posted July 15, 2019 A CC-01 needs new body steering is screwed and the gears sound awful looking forward to stripping and rebuilding. 1 Share this post Link to post Share on other sites
Running Fox 70 Posted July 15, 2019 Thank God fornthe postman. I ruined my Fox and have no time to restore it or start on the Novafox kit whichbis lying arround for a year. What am I going to run with my kids while staying at my parents? Time to get that Hornethopper running again. Needed some parts though. 2 Share this post Link to post Share on other sites
mastino 1085 Posted July 15, 2019 No Tamiya related... A new toy for my pleasure. 5 Share this post Link to post Share on other sites
Blista 1519 Posted July 16, 2019 Picked up a CR01 today. Bearings are on the way here. 5 Share this post Link to post Share on other sites
TurnipJF 9192 Posted July 16, 2019 A carbon ESC tray for my Thundershot, as designed by fellow forum member @ThunderDragonCy: 3 Share this post Link to post Share on other sites
