brass and aluminum will not solder together. this is actually a pretty good idea if you could get the mount rigid enough. this waqy you make a strut tower brace and body mount all in one.
Low Cost, Stronger, Easy to do...
Bye
Now, thats a great idea. I like the feature with the metal bar locking the screw from comming loose.
What excacly is the braas thingy?
Jimmy
Interesting... I was thinking along the same lines a while ago, but I was going to use aluminum tubing and tap the ends for screws instead of using body clips. It seems like I so rarely remove the LB's body that it would be more secure with screws, and look cleaner, too.
Jimmy
Its the inside of one of those electrical connectors pictured.
It may be a little neater to use the body of a small slide bolt for the bracket instead, you know, the things you use to lock a bathroom/cupbard door etc.
