Hi every one, I have just got a second hand tamiya globe liner and I know nothing about them.
Can any one help me with how to set up the gear box so I can change gears, at the moment it has 2 plastic clips on one end of the slider holding it in 1st gear
how do you set it up so I can change gears while driving? do I use a servo to run the slider and if so how does it work so it holds in the selected gear? sorry if this is a silly question but I'm new to this sort of thing. Thanks
Here is the manual for the Aeromax Basically the same chassis
You need a servo fitted to select each gear , the servo just holds the selector rod in that gear
http://www.tamiyaclub.com/manuals.asp
http://www.fusionhobbies.com/v/vspfiles/V4...ight_hauler.pdf
The plastic clips are there just to lock it in one selected gear if youre not using multi channel radio
Hope that is of some help :-)
Ok thank you I see how it works
