got a few questions ,so if anyone can help that would great
i have a blackfoot extreme and want to make it 4wd.would any tl01 gearbox be ok or a wildwilly 2 one be ok?or are they different to the blackfoot/twin detonator types.
can the speed tuned gear set for a tl01 be fitted to the blackfoot extreme ,and if yes is there any benefit?
which esc is better mamba max or traxxas vxl for brushless?
thanks for any help
thanks for any help
A WW2 / Wild Dagger type chassis gearbox would be ideal, as it is a complete package for your BFE, the BFE has the casing, but not the internals, so if you can get either the internal, or a complete built up gearbox to slot into your chassis.
Adam
The part number for a complete assembled gearbox is 8085027. Unfortunately, I think it's been discontinued. You can still build one up using the gear set and the "A" parts tree.
hi
thanks for the reply's.but i have worked out that it will cost about 20-30 pounds.so i bought a dualhunter .
