Many universal shafts have been on the net made by square, tech racing and surely others. finally Tamiya have a set of universal shafts for the TT-01, I hope to be buying them for my TT-01, the numbers are 53792 for the shafts, search on ebay stores and you should find them.
Make sure you get the relevant cups to go with them or I believe they won't work correctly. You will need either:
53790 Cup Joint Universal Shaft when fitted with Standard Differential
53806 TT01 Ball Differential Cup Joint for Universal Shaft when fitted with Ball Differential
53590 Cup Joint for TB01 Reinforced Front One Way Unit when fitted with Front One Way Unit
Adam[;)]
