This car has unique hubs, the only compatible hub is for the 959 (which is essentially the same car). The car is a 1/12th as such 20% smaller than a 1/10th, the wheels would look wrong even if you could get them to fit. These two cars were unique and both ran a Technigold motor, which is the correct motor.
Good luck
Paul.
Yes, I think you are right, I am sure any of the Techni series (power, gold, tuned) would work as they are all based on the same motor.
Hi..
I think you can use the Avante's wheel hub to use 1:10 wheels ,
I have done it in the past to my 959 runner..You can see it in my showroom.
I fitted Lancia's integrale wheels just to test the look of it.
Its fanatstic :D
That is a great idea! Looks good. You can also use Celica wheels instead of the 959, which are white instead of the Porsche's yellow. If you are feeling flush, check out Rad22rad Alloys, who does beautiful machined alloys sprayed white, just like the Dakar original 7 spoke.
Kind regards, Paul
Thanx, i have 2 celica's and one is almost in perfect condition, the only thing that missing is a body that isn't cracked.
The other one has some broken parts that i have fixed "homemade style". It is that car i will use 1:10 wheels and a other motor on.
zulu69 can you post a link to the wheel hubs
