Couple Of Chargers,12v Psu Etc
fastboy
small mains 12v 7 amp psu with built in fan 15 inc postage(ideal for using your 12v field charger for home use)
550 watt 12v mains psu 30amp on 12v output,fan ontop has a fin broke off(it got broke in my bag on way to a meeting last time it was used) but otherwise works perfect,comes with mains lead. 21 posted.
ansman mains/12v charger 1-4 amps for stick packs and trickle for reciever/transmitter 15 posted as its very heavy sold
propeak charger mains/12v 7.2-8.4v 3.5 amps charge rate 15 posted as its very heavy.
4 truck wheels/tyres 14mm hex, 87mm wide,170mm tall,no wear to tread pattern 17 posted as again heavy.
2 pairs(4 tyres) grip2 tyres GM08A for 1/8th buggy,new in box 16 posted
as always paypal,cash is fine.
cheers
dave
Howdo are you in the UK? I have just put a post up for charger info. i used to be into RC about 15-20yrs ago but need new equipment.. how long would these chargers take to say charge a 3000 mah battery?
cheers
yes im in the uk
the red charger has 3 different charge rate settings.
at 1 amp it would take 3 hours
at 2 amps it would take 90 minutes
at 4 amps it would take 45 minutes.
dave
Pro Peak 2500 AC/DC Delta Peak Fast Charger
The Pro Peak 2500 AC/DC Delta Peak Fast Charger has the following features:
Main Features:
AC220/230v and DC12v input voltage
Delta Peak Cut Off
Auto Trickle Charge
Fast Charge 3.5Amp
Slow Charge: 130mAh 4.8~9.6v AC / -130mAh 4.8~8.4v DC
Fast Charge 7.2~8.4v NiCad Packs
Slow/Fast Charge 4.8~8.4v NiCad/Ni-MH Packs DC Input
Slow/Fast Charge 4.8~9.6v NiCad/Ni-MH Packs AC Input
Audible Error Alarms:
Output Disconnection
NiCad/Ni-MH Short Circuit
Low Input Voltage
Auto Shut Down
Reverse Polarity Protection.
Manufacturer: Ripmax
Model: 0-IP2500 Pro Peak AC/DC Delta Peak Fast Charger
