First free weekend for ages, had a TLT to do :D
First off, strip the axles down, and fit some beefy shafts from TCS.
Started at 9:27 this morning
Trussed rear axle
TCS Clocked Cs - allow for better UK angle by rotating axles but keeping knuckle angle
Wheelbase Jig, 12"
One of the most useful boxes in the toolkit
Link mount spacer tubes are from TLT - Part BC7, normally used as part of the mounting for the shocks
Clocked front end showing UJ angle again
RC4WD R2D Transmission - Integy 55t lathe motor and cheap Futaba servo.
Pinion must be set before mounting the servo plate, as it obscures the motor screws
Axle truss fitted and working
Rear lockouts
ESC Plate (receiver on R2D)
Battery placement - not the prettiest, but functional
Droop shocks
And finally...
Not too bad looking for an old man. :)
I like that you are going with a droop set up. The only thing you need to do now is brushless. Live in the now!!!!!!!!!
