Like it says on the can... ;)
Does anybody know wether the Lunchbox wheels will fit straight onto the King Blackfoot with out any modifications or alterations etc? :wub:
Cheers all :D
The front ones will go right on, but the rears use different adapters. The LB is the old 5-point adapter from the early days, and the KBF is the more modern 12mm hex.
Wild Willy 2 wheels, however, which are the same size as LB/MP wheels, will bolt right on. But be aware that they're smaller than stock Blackfoot wheels, so you'll lose some ground clearance and speed.
Mad Bull Wheels work too, same as the Wild Willy 2 wheels just in yellow not chrome.
While the lunchbox/Wild Willy 2/Mad Bull front wheels will fit on the king Blackfoot front axles, you need to watch out for clearance issue with the front uprights, I think you will find the come in contact with the back of the wheels. Lunchbox uprights will bolt straight onto the king blackfoot but may limit the steering angle a little more than the stock items.
