Sign in to follow this
Belly123
King Hauler With Tamiya Mfc-01 Speed Indicator Problem
Hi all,
Just built a King Hauler with MFC-01 and am really happy with it. Apart from the speed indicators on the roof. They light up the wrong way!! 3 lights in first gear two in two then one in third.
I've tried reversing the channel on the transmitter/changing the light order round on the MFC unit but this doesn't work.
My transmitter is an ACOMS Techniplus 4 by the way. I have noted some of the special functions (light switching etc) work with the trims the oposite way to the instructions, does this have something to do with it??? Or should a try a different servo???
This is only a small issue but really annoying, please help!!
Thanks in advance.
Welcome,
Redo the centering/calibration of the MFU, usually sorts out odd problems with the MFU.
Sound like it was done "reverse" , you might have to reverse the motor wires after that
Good luck!
Stefan
Welcome,
Good luck!
Stefan
Thanks Stefan will give it a go tomorrow!
