will a novak gtb bl setup fit on the frp chassis set for the ta02? the system is relatively tall because of the fan, but i wanted to know if there's enough space between the chassis and upper deck.
There is 36mm between the decks. I don't know the dimensions of the Novak gear, but wouldn't you normally fit that on top of the top deck?
thanks for the information, i'll have to measure the height of my gtb. anything that i can get on the bottom deck for weight distribution, i'd prefer and the sensor harness for the motor isn't that long. would you happen to know if side by side or lipo packs can fit in the battery holder?
the dimensions of the gtb are 29.5x37.8x1.3125mm. would that fit on the chassis with the servo mounted all the way right and battery tray mounted all the way back?
