If it's a brushless, it might explain the bent suspension link...
Nice truck. Just so long as the electronics are from Traxxas, and not Cyberdyne. :lol:
the bent link(s) is an option part, kit has straight links
The VXL is mental i9n there, can pull a wheelstand and still has low speed control without cogging. Great system. :D
Thanks Guys for the compliments. :lol:
Thanks for the correction, I'm sure the VXL is awesome :lol: How is the stability? Do you get any chassis twist? did you need to stiffen up the suspension? Is the AX-10 stock gearing low? and did you gear up?
Thanks for the correction, I'm sure the VXL is awesome <_< How is the stability?
Not bad, could be a bit better if wider for side hills
No, barely any chassis twist I have 2 extra aluminum crossmembers. Shocks are traxxas maxx big bores, maybe even a bit to stiff.
Yes, trans is geared low. Stock pinion spur is 14-87 I have in it 16-86 and plan on dropping to 13-87
