Heres a few picks of the Brat with my new front shocks which were kindly donated by Evirob Cheers mate.... these are mounted on the team CRP mounts. and i have fully ballraced rebuilt the gear box with new parts all the wheel housing and mounts are brandspankers and i have got to say even with a very old stock 540 motor it goes pretty fast a lot faster than what it did when i was a kid... well heres some pics.
Looking good. I'm thinking about doing the same thing with my re-release brat. Do you know what kind of shocks you are using?
Also could you measure the diameter/width of the shock body (with and without the preload adjuster)?
I have a spare set of Tamiya touring car shocks that I’m wondering if I can use.
I think they were from this user on ebay
ebay shocks
and the width with is 18mm without is 14mm (i measured these without taking them off so its a pretty good guestimate) and the overall lenght is around 65mm
hope that helps
ebay shocks
hope that helps
You're welcome mate, great to see them in use!
Yeah, that's the ebay user I got them from.
I found the yellow springs a bit bouncy, so I switched them for the blue, although I'm yet to give it another bash.
you think... i think the yellow ones are pretty hard may give them a swap to the blue ones and see what the difference is?...
Yeah, it's the stiffness that made it bouncy, I think. The softer blue should (hopefully!) absorb shocks better and stop the front end taking off, which is what I found happened with the yellow.
are now i see what you were saying, yeath they are really stiff, i havenot yet run it with them on but i am going to change them to the softer ones
