hay all, been thrashing me wild dagger around loads last few days, today was having a quick clean up etc, and i noticed how much flez the steering servo has, is there any was to cure this? im gona try alloy mounts from a tt-01 as i have them to hand, but i dont think this will cure it, ny one else noticed the same thing?
cheers snake,
I'm very pleased that my new alloy chassis has a much stronger servo mounting plate - but I discovered during the conversion that I've stripped the gears in yet another servo!
I think next month I will buy some hi-torque servos for all my hard runners, and fit Kimbrough servo saver to the Dagger.
Thank you for the link Woolfy! I will try that mod.
Mad Ax. I have good results from Hitec's hi-torque metal gear servos and Kimrough 124 servo savers. I use 'em on most of my monster trucks. I just have some delivered today and gonna install them on my double blaze as well.
Oh, got some 2.2 badlands as well. nice tires!
cheers guy's i have put the tt-01 alloy servo mounts on, and part of a dfo3 shcok tower (it was broke any way lol) and it has took almost all the play out, so im much happier now , snake
Hi snake. What part number is that TT-01 servo mount and also what part of the DF03 shock tower. Thanks.
hay, heres the servo mounts i used, i originally baught them for my tt-01 ut at that price gona re order :-) link
as for the dfo3 shack tower, used this part from the standard plastic towers, its the top bit the shocks mount to on the rear tower. its a nice tight fit, not picture is not the stock item its just to show u which bit i used (circled in red)
hope this helps snake
Nice. Thank you for the link and pics.
Will you be able to take some pics of it in your dagger? Thanks.
ok mate heres the pics as rrequested, im sorry i know there not the best but im **** with a camera you can see it in the last pic, and the pick before the is the screw hole i used, again im really sorry about the quality of the pics (screw hole is the top one on the ltop left of the switch cut out part)
It is a little blurry but I got the whole picture. That is one way of securing the steering servo.
Thanks again.
