Hi all. You may well have seen miy pictorial quiz from the main site regarding the recent purchase of 2 Venom Fireball 21x2. These are for my Clod project and I got them because a) They are sensibly priced and b ) They came with pre installed caps and connectors. Sadly, whilst a) is still correct b ) is not so as when they arrived they were the bare motor with no cabling.
I have managed to make the bullet ends up thanks to a Tamiya Snap Connector set but before I set to a frenzied soldering session (far from being any good at said soldering but have som every useful tips from 'tinterweb), I thought I would ask if anyone knew if the slide/clip on connectors that connector the motor wire, are availble seperately or what they might even be called so I can search for them? i.e. you have a pre made wire come with the motor normally, one end has bullet style for ESC conenction and the other is a connector that slots into place on the fitting that forms part of the eyelt fitting (a big U shaped bit of metal!).
I know I can solder direct to the motor but in the interest of science I am keen to find out if those parts are available. I have tried Venom's website and Googleised most things I can think of, any thoughts?
You are better off removing the poor quality, poor conducting, easily loosened bullet connectors completely.
Solder directly to the motor. If you need it to come apart use a high volt plug (female on the esc) the same as you would use for a battery. Not the Tamiya plugs....they are worse than the bullet connectors.
The bullet connectors are available on eBay but are a complete waste of money.
The Venom motors are not too bad for the price. Of the 3 I've bought in the past 1 was a dud. It was very out of balance and did not last long at all. A 21x2 Orion or Trinity is a completely different class of motor to a Venom 21x2. You will probably also find that a Tamiya 23 turn will out perform those Venoms. My LHS refuses to stock anything Venom now, he got sick of returns.
Mark
Mark
Thanks for that Mark, yeah I guess you makes your choice and takes your chance etc. I will give them a go for now as I am only a garden/park driver anyway and see how they do. Mind you, I wasn't filled with confidence when the back of the packet says things contrary to what you actually get!
