I have a JunFac full conversion on the way.
I was wondering if anyone else is using this conversion, and if they like it?
I also have Axial Chrom Bead locks and Pro Line MOAB tires on the way as well.
The F350 will be looking good!
Here are pic's of what is coming!
I started to use one for my Hilux build but found it wasn't compatible with my MFU and the rear Hilux Body mounts.
So I had to go with a Mono tuning
Junfac just came out with a hilux chassis I may get. So I am going to use it on my orange High Lift
The quality of workmanship is excellent, I just wish they were about $70 cheaper.
My recomend would be rubber sealed bearings and rubber covers for the universal joint. the mud and water will kill those parts
** DROOLS **
My wife said a definite NO when I told her about this chassis. :`(
I'm waiting for them to do a better version of the gearbox before I complain until she gives in. I want 3 spd and a seperate transfer case to switch between 2WD, 4WD high & 4WD low instead of the current setups with 2WD in the higher gears and 4WD in low or always 4WD.
It already has rubber sealed bearings throughout, I just need the ones for the Universal Joints then.
Thanks for the advice. :unsure:
Hey,
What size/make are the wheels and tyres on this truck. I've been considering replacements for my Highlift and these look excellent!
Fraser.
Hey,
Fraser.
Which truck are you referring to ? If you mean my High Lift then I bid on the wheels from Ebay Seller: chiang580324 (Link is to closed auction won by me admin)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...em=280216745383
He lists them all the time. The tires ? They are the tires from the new Tamiya CR-01 Land Cruiser ! They were purchased separately from RC-Champ. Part #51324 I htink. Also available here:
http://www3.towerhobbies.com/cgi-bin/wti00...=LXUGZ7&P=7
I think however, I require slightly longer wheel axle hubs for the wheels as the lock nut doesn't seem to thread all the way down into the nylon. But, mine is for the shelf so it doesn't matter - the test runs in the living room were okay though :) .
