Hi guys, was running my high lift hilux and everything jammed up and it wouldnt go no further. turns out the tiny circlips fell off one of the propshaft pins and the metal pin was hanging out. i was lucky that the pin was still there but the circlips are long gone. sort of annoyinjg as this is the only part tamiya ready built! anyone know where i can get these circlips, they are tiny! seems like madness that the whole truck be disabled because of that :unsure:
Don't know the diameter of the pin, but Modelfixings usually have just about any size of hardware you'll ever need.
cheers terry. just need to work out the diamater of the pin then. perhaps i should email tamiya, does anyone know the adress that you email them at with problems such as this?
The TNX has pins like this on it's driveshafts
The E-clips for that are 2.5mm (I think!!)
In the TNX instructions it says to put a blob of
threadlock on the clips to help stop them coming loose
and falling out
Wouldn't it be easier to just put a ruler across the end of the pin? :unsure:
i did that yeah but was thinking more a micrometer. anyway looks like 1.2 or 1.5mm to me so im going to order both from your link terry. there so cheap it dosent really matter if i get the wrong ones. thanks for the help, ill let you know how i get on.
I too have just found that my c-clip came out, fortunately I found out whilst cleaning, and was able to fit a clip I salvaged from the WELL used previous shafts fitted. I have just covered them all with thread-lock, will keep an eye out on them again.
Mine fell out too! i think it's a common problem.
replaced mine with a small nut & bolt untill the traxxas ones turned up in the post.
There alot quieter too!
hey guys, my replacement parts from modelfix came today, the 1.5mm circlips fit ok. seems like its a common problem! thanks for all the tips mine too are now covered in threadlock!
interested in this traxxas thing now though and will probably order some soon as, they have good stock on ebay!
Gaz
