Okay I'm an old school kind of guy and need a little updating. My collection is mostly old tamiya cars so when I built my new df-02 chassis,I came up on this little question.I wanted to update the gear diffs to ball diffs,which I did. But....I had another choice for replacing the front diff-with a one way unit. Huh???? What the heck is a one way,and briefly if you don't mind,explain to me the basic function of a one way is and what it does,how it works etc. Thanks [8D]
I have a one way front diff in my procat offroad buggy. Am not sure if a DF02 is onroad or offroad but the operation of the diff on my procat means that when i am accelerating all the wheels are transmitting power to the ground. When i brake however the braking goes to the rear wheels only. this stops the front of the car nose diving under braking or locking the front wheels completely on a very loose surface ( locked wheels don't steer, regrardless where they point). Also the rear of the car becomes looser under braking and can help the turn in. I have only driven one road car with a one way and it was very twitch under braking, this may have been the car setup, my driving etc tho. Basically if you stick your car on a stand and give it full throttle then full brake the rears will stop and the fronts will free wheel till there own inertia runs out.
Hope this helps,
Dodge
the idea of a 1 way is to give the car a little more steering,if your suffering from understeer then give it a go,but you will sacrifice some braking power.
