Just finished building my Dualhunter.
Haven't had chance to run it yet, other than a quick test across the kitchen floor.
Couldn't face painting it in the stock colours with pink stickers, so went for this scheme instead.
I can't decide if it needs some more decals or if I should leave it as it is now.
Thats more like it. Looks more meaner than the pinky colors, lol.
Now get 'er dirty.
Btw, what is your set-up?
Yahoooo!!!
Just been blasting it round the garden. Up some pretty steep hills and a few low jumps off the edge of the patio.
Plenty fast enough for the time being. I love it.
4wdmt. It's bog standard apart from some 70mm oil filled shocks off eBay and ball bearings throughout.
70mm shocks
I ordered the ball bearings off the same seller, but only 20 were supplied. You need 24 to change all of them including the gearboxes.
For now, I've put 4 bronze ones in the outer hubs as these are the easiest to get to to swap later. I've ordered 4 more locally and will swap them over when they arrive.
Transmitter is a Futaba 4EX, which I use for the F350 as well. It has a 4 model memory which is handy.
4 channel Futaba micro Rx connected to a standard Futaba servo on the steering.
4600maH Intellect battery pack.
Masked the windows out prior to painting the top half with Tamiya PS23 Gunmetal. Body is PS17 Metallic Green. Wheel rims in PS23 as well.
Not sure how long the paint will stay on the rims.
Still time for another run ;)
