i have a TL01 chassis which is running a 19 turn with 21 pinion witht the tamiya speed tuned gears. what would be the the lowest turn motor should i ever go? what pinion should i run with it? is 21 ok with my 19turn motor? i have two esc's so i can either go to 15 or 8 turn. thanks. also how can i improve steering of the car?
You can improve the steering by buying a faster speed servo for it,not a high torque one as these are for off road,but a higth speeed!Also get your steering ballraced will make it smoother if it is not![:)]
Regards,pete.
