coslatch 0 Posted July 5, 2008 hi , has anyone tried connecting 2 7.2v batteries in parallel in a buggy , to give longer running time etc Share this post Link to post Share on other sites
natedog 0 Posted July 5, 2008 I wouldn't recomend it. I'm not completely sure, but wouldn't that mean double the voltage? Share this post Link to post Share on other sites
Illacrew 0 Posted July 5, 2008 Nope but it would mean double the weight and 1/2 the performance Share this post Link to post Share on other sites
terry.sc 16 Posted July 5, 2008 Wiring two batteries in parallel basically doubles the capacity of the pack, so if you use two 1800mah packs you effectively have the same capacity as one 3600mah pack. It will run a little bit slower with having to haul the extra weight of the pack around and you will get almost double the runtime. Although it is really a pointless idea as you'll get more speed and slightly longer runtime by just using two batteries one after the other. Share this post Link to post Share on other sites
MRD_1982 0 Posted July 6, 2008 If you use two lipos the weight isn't as much of an issue. I use two in parallel in my boat and haven't had any problems so far. Share this post Link to post Share on other sites
WillyChang 1814 Posted July 7, 2008 many LiPos are already in parallel eg "2S2P" to make 7.4V means there's FOUR cells in there, 2 parallel 2 series Share this post Link to post Share on other sites
