driftking_v8
Servo/motor Problem
If my motor goes to hard, my servo goes trilling, it becomes very ''nervous'' and i cant steer ??
what's the problem ??, srry 4 my bad englisch
Does your motor have capacitors?
If not, it's likely to be interference...(and you know the fix: add capacitors to your motor).
do you know where I can buy one ?? a website plz
grtz Marc
also a large current draw will cause weak response from a servo if the BEC, Batter Eliminator Circuitry, does not provide enough amps
2 simple ways to help fix this without spending much money
drop a few pinion teeth
run a reciever battery
Other than that I'd suggest a less powerfull motor or better ESC
thanks man awesome I now use a receiver battery and it works sow the
servo had probably almost no power
ty Marc
