driftking_v8 0 Posted July 21, 2008 If my motor goes to hard, my servo goes trilling, it becomes very ''nervous'' and i cant steer ?? what's the problem ??, srry 4 my bad englisch Share this post Link to post Share on other sites
mb_c11 0 Posted July 21, 2008 Does your motor have capacitors? If not, it's likely to be interference...(and you know the fix: add capacitors to your motor). Share this post Link to post Share on other sites
driftking_v8 0 Posted July 21, 2008 Does your motor have capacitors?If not, it's likely to be interference...(and you know the fix: add capacitors to your motor). do you know where I can buy one ?? a website plz grtz Marc Share this post Link to post Share on other sites
grizy 12 Posted July 21, 2008 Your local RC hobby shop should have them or you could try an electronics retailer. As an example RC Planet - Motor Capacitors And heres how you should fit them Installing Motor Capacitors Grizy Share this post Link to post Share on other sites
billg4 25 Posted July 21, 2008 also a large current draw will cause weak response from a servo if the BEC, Batter Eliminator Circuitry, does not provide enough amps 2 simple ways to help fix this without spending much money drop a few pinion teeth run a reciever battery Other than that I'd suggest a less powerfull motor or better ESC Share this post Link to post Share on other sites
driftking_v8 0 Posted July 21, 2008 also a large current draw will cause weak response from a servo if the BEC, Batter Eliminator Circuitry, does not provide enough amps2 simple ways to help fix this without spending much money drop a few pinion teeth run a reciever battery Other than that I'd suggest a less powerfull motor or better ESC thanks man awesome I now use a receiver battery and it works sow the servo had probably almost no power ty Marc Share this post Link to post Share on other sites
