carparkthrasher 1 Posted September 10, 2008 Hi all, Yes, this be this years post from me! I have searched for the answer but not really come across it yet. I have just aquired a used bodyshell that has had the windows smoked, i.e. given that tinted look. As I have just spent some time painting a driver set for the car, I would like to remove the smoke paint from the windows. Any suggestions on the best product to use? Obvioulsy whatever I do needs to be done with care but I wouldn't know where to start in terms of chemicals and so on. Many thanks Simon Share this post Link to post Share on other sites
Spetz83 0 Posted September 10, 2008 I heard DOT 3 or 4 brake fluid works well for paint You gotta leave it on the paint overnight though, and then the paint just peels off easily Share this post Link to post Share on other sites
bigoggy 203 Posted September 10, 2008 brake fluid only works on abs body shells. if you have a lexan shell the best thing to do is get some nitro fuel and apply it to the areas you want to remove the paint from with a cotton bud. leave it to sit a while then wipe off and clean. you may need to do this a few times as you will only be giving it light coats of fuel Share this post Link to post Share on other sites
carparkthrasher 1 Posted September 10, 2008 brake fluid only works on abs body shells. if you have a lexan shell the best thing to do is get some nitro fuel and apply it to the areas you want to remove the paint from with a cotton bud. leave it to sit a while then wipe off and clean. you may need to do this a few times as you will only be giving it light coats of fuel Thanks chaps, FYIit is a poly bodyshell so pinted from the inside etc. My only concern leaving anything 'soaking' for a while is geting run off into areas that I want to keep painted. Deliate operation methinks! Share this post Link to post Share on other sites
Blacque Jacque 4 Posted September 10, 2008 I second bigoggy's advice, a cotton bud & nitro fuel, doesn't need to be new, but higher nitro % seems to help. If it's polycarbonate, don't get brake fluid anywhere near it. It will strip the paint, but it also irreparably damages the poly which will become brittle & just crumble. Share this post Link to post Share on other sites
andi4x4 1 Posted September 10, 2008 Thanks chaps, FYIit is a poly bodyshell so pinted from the inside etc. My only concern leaving anything 'soaking' for a while is geting run off into areas that I want to keep painted.Deliate operation methinks! One thing you may have a problem with - Paints designed for lexan/polycarbonate bodies are designed to "etch" into the lexan and bond themselves to it. If your windows have been done with a proper lexan body paint, then you will never get the windows clear without a lot of very careful and gentle polishing. On the other hand - paints not designed for lexan should come off very easily as they dont bond to lexan properly. Hope it comes off easy for you ! Share this post Link to post Share on other sites
Origineelreclamebord 45 Posted September 10, 2008 Maybe you should put on paper tape on the windows... It will soak up the nitro fuel, making sure the rest of the paint doesn't come off? Never tried it or heard anyone doing this, but it might work? Share this post Link to post Share on other sites
WillyChang 1814 Posted September 10, 2008 surefire way is to mask off the areas you want to keep, then sand away the painted window areas start with 600grit, work towards 1200, 1800, 2400... finish off with Polishing Compound or Brasso. if you want them sparkling clear easier, i'd go paint a coat of clear varnish on them, try the Clear in Tamiya's Acrylic X-bottle Share this post Link to post Share on other sites
carparkthrasher 1 Posted September 10, 2008 surefire way is to mask off the areas you want to keep, then sand away the painted window areasstart with 600grit, work towards 1200, 1800, 2400... finish off with Polishing Compound or Brasso. if you want them sparkling clear easier, i'd go paint a coat of clear varnish on them, try the Clear in Tamiya's Acrylic X-bottle Thanks for all the thoughts folks, I reckon it was probably done with Tamiya PS Smoke so it does looklike either nitro fuel or sanding are my options! I don't have any nitro so I will try a bit of gentle sanding first and see how I get on. The obvious answer is to start fomsratch with a new shell but it is a Scooby and the rally declas drive me mental when applying so I would prefer to use this one! Share this post Link to post Share on other sites
irenL 0 Posted September 10, 2008 I've used brake fluid on polycarbonate.. no ill effect. just apply to paper towel or cotton-butt and rub away. clean up residue with window cleaner (non-ammonia base). Share this post Link to post Share on other sites
bob3.3 0 Posted September 23, 2008 bolink sells or use to sell body wash i got a bottle of it with a recent purchase i've made. it said one of the uses is paint removal but i havn't tried it yet Share this post Link to post Share on other sites
