garry
New Releases from Tamiya
New releases at the All Japan Plamodel Radicon Show
Recently, Tamiyablog presented information about some future RC-models from Tamiya. Since then, several sources have announced further new items, which we havenâ„¢t listed as the information was relatively easily available for anyone with a minimum of dedication. However, with Tamiyaâ„¢s most recent announcement in Japanese for the All Japan Plamodel Radicon Show in October, we feel obliged to list a few future releases. However, whereas Tamiyablog usually doesnâ„¢t present any news before they have been verified by the most reliable sources, please note that some of the information in this post may not be entirely correct due to possible errors in the translations and interpretations of the original Japanese text. Also, some of the information is listed as Å“tentative even by Tamiya themselves. Furthermore, some of the listed items may be limited edition items available only at the fair and/or on the Japanese market only. Descriptions will be updated and corrected, and pictures posted as soon as further information gets available to us.
Radio Control:
- 1/10 TRF416 World Edition Chassis Kit
- 1/10 F103 Chassis Kit 15th Anniversary
- 1/10 F103RM (w/L-body) (Limited Edition)
- 1/10 Subaru Impreza WRC Monte Carlo'07 (DF-03Ra Chassis)
- 1/10 NISMO R34 GT-R Z tune (TT-01D Chassis)
- 1/10 TB-03D Chassis Kit (drift version of the TB-03 Chassis)
- 1/10 XB Lamborghini Countach LP500S (TT-01E) (XB version of # 58413)
- 3.5T / 6.5T / 7.5T Brushless Motors
- Brushless Speed Controller
- High-performance charger (tentative description)
- 24A stabilised Power Supply
- Aluminum Servo Horn for High-Torque Servo Saver (M-Chassis)
* 1/10RC TRF416 world edition
* 1/10RC F 10,315 TH anniversary chassis kit
* 1/10RC F103RM (the L body you attach) (limitation)
* 1/10RC XANAVI NISMO GT-R (R35) (TB-03)
* 1/10RC [ranboruginikauntatsuku] LP500S (TT-01E)
* 1/10RC Toyota TUNDRA high lift
* 1/10RC rising fighter
* 1/10RC in presser WRC Monte Carlo '07 (DF-03Ra)
* 1/10RC [nisumo] R34 GT-R Z [chiyun] (TT-01D)
* 1/10RC TB-03D chassis kit (tentative name)
* XB NISSAN GT-R (TT-01E)
* XB rising fighter
* XB [ranboruginikauntatsuku] LP500S (TT-01E)
* 1/35RC American M4A3 shaman tank (4ch unit attaching)
* 1/14RC [sukania] R470 metallic special full operation
* High performance motor tolane speed brush less 3.5T/6.5T/7.5T
* [haipahuomansusupidokontororavuoratsukuburashiresu]
* HL cylinder for TRF special damper (2)
* HL cylinder for aeration damper (front 2)/(rear 2)
* HL cylinder for M chassis high grade aluminum damper (2)
* Advanced charger (tentative name)
* Stable type power source 24A (tentative name)
* [OP] DB01 aluminum motor mount (blue)
* [OP] TB-03 aluminum racing steering
* [OP] TB-03 carbon steering wheel link
* [OP] The Toyota land cruiser 40 plated grille
* [OP] CR-01 plated standard wheel (offset 0)
* [OP] CR-01 heat sink motor plate
* [OP] CR-01 aluminum servo mount
* [OP] CR-01 strengthening drive shaft & diff-lock
* [OP] CR-01 Al Mr. face bead lock ring (2 sets)
* [OP] CR-01 carbon mechanic deck
* [OP] DB01 assembly WO universal shaft (front)/(rear)
* [OP] Aluminum horn for high torque servo saber (M chassis)
* [OP] [haitorukusaho] â„¢ [seiha] â„¢ - business aluminum horn
* [OP] New pattern tire (2)
* [OP] Carbon damper stay (rear)
And all that in English from the Tamiya English site:
* 1/10 R/C TRF World Edition
* 1/10 R/C F103R 15th Anniversary Chassis Kit
* 1/10 R/C F103RM (W/T-Body) (Limited Edition)
* 1/10 R/C Xanavi NISMO GT-R (R35) (TB-03)
* 1/10 R/C Lamborghini countach LP500S (TT-01E)
* 1/10 R/C Toyota Tundra High-Lift
* 1/10 R/C Rising Fighter
* 1/10 R/C 4WD Subaru Impreza WRC Monte Carlo '07 (DF-03Ra)
* 1/10 R/C NISMO R34 GT-R Z-Tune (TT-01D)
* 1/10 R/C TB-03D Chassis Kit
* XB Nissan GT-R (TT-01E)
* XB Rising Fighter
* XB Lamborghini countach LP500S (TT-01E)
* 1/35 R/C M4A3 Sherman Tank (W/4ch Transmitter)
* 1/14 R/C Scania R470 Highline Metallic Special
* HP Motor Transpeed Brushless 3.5T/6.5T/7.5T
* HP Electronic Speed Controller Volac Brushless
* HL Cylinder TRF Special Dampers (2pcs.)
* HL Cylinder for Aeration Dampers (Front, 2pcs.)
* HL Cylinder for M Chassis Aluminum Dampers (2pcs.)
* HP Battery Charger
* Stable Power Supply 24A
* [OP] DB01 Aluminum Motor Mount (Blue)
* [OP] DB01 Assembly WO Universal Shaft (Rear)
* [OP] TB-03 Aluminum Racing Steering Set
* [OP] TB-03 Carbon Steering Link
* [OP] Toyota Land Cruiser 40 Metal Plated Grille
* [OP] CR-0140 Metal Plated Wheels 2pcs. (Offset 0)
* [OP] CR-01Aluminum Heat Sink Motor Plate
* [OP] CR-01Aluminum Servo Mount
* [OP] CR-01Reinforced Drive Shaft & Diff Lock
* [OP] CR-01Aluminum Beadlock Ring (Star,2pcs.)
* [OP] CR-01 Carbon Mechanism Deck
* [OP] CR-01 Cliff Crawler Tires (2pcs.)
* [OP] Aluminum Horn for High Torque Servo Saver
(M Chassis)
* [OP] Carbon Damper Stay (Rear)
Source: TamiyaBlog
That is some serious power!!!!
3.5!!!! :o:o i have a 6.5 novak and that is nuts- man i feel the need..... just been looking at novak and they do a 6.5 brushless drift set called the slydr. i was led to belive that torqueier(? :P ) talkier(! :lol: ) motors were better. comments anyone?
Updated the list with a translation from the Tamiya Japan site, lots of option parts and an full-function metallic Scania.
i noticed that. i too got a little excited! i also noticed in the second list garry put down it had been translated from impreza to in presser. hehe :P
Sniffing around some Japanese blogs....I found this, not sure if its been posted before as this forum isn't my usual hideout. :P
Rising Fighter
And
Oh yeah, Tamiya's English site has a full list of what should be on show next month, so I've added it to the first post.
Foibles of babelfish.
Countach = ranboruginikauntatsuku
:P
hehe, bit of a mouthful! that rising fighter has been on i'm pretty sure. Based on a GH2/Super Hornet by the looks of it so fingers crossed there will be a big supply of spares soon on the market for me to do my GH Super G. And as for that Nismo.. :lol::o (picks chin up off floor) Just realised, is that the Nissan Clarkson raced Hammond and May across Japan in on Top Gear?
Higher res pic of the Countach.
New Nismo car (Click on picture for TamiyaUSA listing)... I don't like the design of it, and it's another nismo, but it is a TB03 release and I have to say that if that indeed is the shell, not a render or drawing, they did an outstanding detailed job!
The rising fighter is the highest resolution pic I've seen so far.
Just saw this on the excellent Tamiyablog.com
"Recently, Tamiyablog presented information about some future RC-models from Tamiya. Since then, several sources have announced further new items, which we havent listed as the information was relatively easily available for anyone with a minimum of dedication. However, with Tamiyas most recent announcement in Japanese for the All Japan Plamodel Radicon Show in October, we feel obliged to list a few future releases. However, whereas Tamiyablog usually doesnt present any news before they have been verified by the most reliable sources, please note that some of the information in this post may not be entirely correct due to possible errors in the translations and interpretations of the original Japanese text. Also, some of the information is listed as tentative even by Tamiya themselves. Furthermore, some of the listed items may be limited edition items available only at the fair and/or on the Japanese market only. Descriptions will be updated and corrected, and pictures posted as soon as further information gets available to us.
Radio Control:
- Aluminum Servo Horn for High-Torque Servo Saver (M-Chassis)"
Click here for the full blog.
most interesting new model? my money is on the new DF-03ra rally chassis. I really hope they make it.
Plus brushless motors? wonder who is making them? and will they be expensive?
let the commenting begin.
Matisse
Looking forward to these!! Maybe the F103 will be a fully tricked out carbon and aluminium beast?
Matt
Charger, Power supply & Brushless Systems!!!! :lol: I hope our economy picks so up so I can buy these (if they are good)!!!
If I had the Ford F350 truck, I would get the Tundra ;) also because the body looks more scale 1/10 unlike the Toyota Hi-lift body :) . The Tundra will look nice sitting next to a F350.
I really like the fact they are bringing an F1 back :D , I never had one and this would be my chance hopefully
I really like the fact they are bringing an F1 back :) , I never had one and this would be my chance hopefully
Maybe we could get a pan-car class goin or something (not that we need more classes)...
After seeing the Toyota Tundra, I want one over the F350 and the Hilux. The Tundra looks much more balance and the lights if all works should melt the paint off the F350 and the Hilux :) I am glad I hold off on getting the new 3spd. :D
So will the F103R 15th anniversary be a F1 style chassis or not? The F103RM is a f1 chassis isnt it?
Yes and Yes
also that update has the wrong body type for the other F103RM it is a "L" Type body. Which is the this
http://www.tamiyaclub.com/car.asp?id=132
which is nice ,but without the decal sheet.Boo
Time then that TC also makes a repro sheet for that :) I'd even be willing to help if the procedures are digital, and someone could tell me what exactly to do.
They aren't premium quality scans, but it's nice to see them. The TB03D has normal front suspension, great! :lol: It looks like the F103 15th anniversary edition doesn't look that extraordinary, but then again, you can barely see anything besides the outlines of the car... And I'd really like to know more about the DF03RA, it's very interesting :lol:
