The large side stripe decal that goes along each side of the car is in three parts which line up to create the effect of one long decal. Only thing is the second part of the decal, which lines up around the rear part of the side window, simply does not fit properly for me. If I line the decal up alongside the window the yellow curved part of the stripe is miles away from the adjacent stripe of the first decal part. Trying to line this curved part up leaves a large part of the decal "floating" as it has no where to go. Now I have managed to get it to look reasonably joined but only by having to get the second decal to overlap the first one, but it looks unprofessional in my opinion.
Has anyone else had this problem?
I had no problem... The stickers do overlap a little bit, but the stripes should line up. One of them folds over the corner at the rear of the cockpit, and the yellow stripe should line up, take a closer look how it all goes on.
- James
I found mine to be quite fiddly as well, but with patience they went on OK. Just take your time, and only remove a small amount of the backing at a time :-)
