Sign in to follow this
bangstick
Blitzer Beetle Pinion Question
Whats the other sized pinion a Blitzer will take?
The reason I ask is because I am installing a Brushless Novak GTB 5.5 in mine, I have the 13t pinion as the manual shows but due to there being 6 mounting holes evenly spaced around the face of the brushless motor rather than 2 at the top and 2 at the bottom like a brushed motor I cant get it to mesh on either of the settings that are on the gear casing.
I'm guessing it's a larger pinion as mines not even touching the spur.
Thanks in advance ;-)
The Blitzer uses a choice of a 13 or 15 tooth pinion. The rearmost upper hole and forwards lower hole in the gearbox are for the 13 tooth pinion, the other pair of holes are for the 15 tooth pinion.
Cheers Terry, nice to hear from you again!
