Ok so i got the other eZrun motor/esc and it comes without connections, np! Except im not sure if there is an order you should use for the 3 cables from the ESC ? I was considering copying the order they use on the other eZrun.
Im also curious what these things are that i have circled, i have emailed hobbywing numerous times but no answer.
Any thoughts?
Yes that's the pack of power capacitors. They are connected to the battery at all times when it's plugged in. They help keep voltage up when you jam on the throttle. Adds a little punch to the motor as well...
Any thoughts?
Whats that all about then? that looks completely differnt to my ezrun - is that the 5.5?
Hi spencem875, did you get this set-up and working yet?
That must be mental!! 5.5T,
What sort of M.P.H will that bring you?
Like a rocket, iv no idea how to check speed, without racing the wife in her astra :D
