Hi,
Pretty new to this, just got a dual hunter car. Could anyone tell me if I get the bigger battery packs eg 8.4 and 9.6 volts will it damage anything? Which other bodykits would fit easily (I dont mind if it means adapting it a bit...)?
Cheers,
Paul.
The Twin Detonator body will fit, as will Wild Dagger and I think the Mighty Bison or something like that [2wd]. You could make the Blackfoot family of bodies fit and the TNX body is pretty close, just a bit longer. You could probably could make it work.
People have modified them to run 14.4 volts with a Traxxas ESC but you have to do something funky to the chassis to make it work. The battery slot will not allow a longer pack like an 8.4 volt.
Hi
I've been running my old Wild Dagger with a LRP 4600 NiMh 7.2v in, gives pretty good power and a much longer running time than the old Tamiya 1400 I got with it
the mighty bull body fits straight on. also look at the hpi or proline bodys as there are some great ones that will fit with a bit of work
If the Dualhunter mounts are like the Wild Dagger, they're different from the BFX. Aside from the metal rod used on the BFX front mount, I think the other mounts are probably on the same parts tree.
I have a Wild Dagger, which is the same as the Dual Hunter; apart from the shell. I am running 2x 14.4v GT550 HPI motors and 2x 7.2v battery packs. It was a little work, in that I had to dremel another battery slot above the 1st one. Other than that, the motors just screw in to replace the standard ones, and I bought the HPI dual motor ESC. Motors were 7 each and the ESC was 60. Speed wise it is just a bit slower than my brushless FD! Have just locked both diffs. Am looking fwd to getting it off road!
