I have a couple of questions about my TT-01, I removed the Prop shaft and Within 2 weeks stripped my gears.. Is that the reason it stripped?
Now for the good stuff...>>
I am going to be buying some parts for my car to make it a racer.
1.I have a 15 turn motor but what gearing should i get?
2.Should I get some special parts since I am using a 15t motor?
3.Putting back the old shaft slowed my car down alot!!
4.Last question... whats the highest speed I can ge with a 15t?
Things I will order >>>
Carbon upper frame
Alum Prop shaft
Alum Motor mount
Radial tires
Bearing set
Spur gear set
Anything else I should add since I will be racing this at the local track?
Sorry so long[:I]
Tom
yep thats y ya stripped it, you put more torque on the gears, but wit the prop you transfer 50% of the torque to the front.
A i am not sure, but mess around till you like the accel/top speed balance.
A yes with a faster motor you must upgrade to a sutiable esc.
A thats normal, if your still worried clean the front diffs
4.Last question... whats the highest speed I can get with a 15t?
A i would say from the high twenty's to the low thirty's (mph)
A.)oil shocks, more graphite parts to reduce weight.
Ok good! Now I know that I didnt strip the gear or something worse!
I ordered 76.00 worth of stuff yesterday.
Carbon fiber upper chassis
Alum Prop shaft
Small pinion
Spur gear set
Heat sink
and Radial Tires.
Anything else I need?
Can I ask what spur gear you got? Was it a smaller one for more top end speed? I've been looking for a spur gear to increase the top end of my TT01 (similar to the speed tuned gear set I have for my TA01) but I haven't seen any yet.
Just one point - have you checked with your local club that a 15T motor is acceptable in the class you'll be running in?
Other than that, in my experience, your list is looking good so far. Experiment a bit with the tyres - they can make a big difference depending on what surface you're on.
I think the Spur gear is a 51t or 55t? Not shure. I have a smaller Bevel gear. So I Should get some decent speed. I have slicks so I just want to see how the Radials will work.
Is there someone that has calculated the top speed on the tt-01 with some hop ups?
  • 1 year later...
