Hop Up & Spares. Mostly Ta01/ta02 & A Few Others
Camel
Drop me a note is any one of these
Pictures available if required.
In UK.
58204 Blazing Star - Complete Kit NIB
Technigold motor
5312-600 Technigold Brush Sets - Retail card
op44 53044 Dynatech 02H Motor SOLD - Payment Pending
Aluminium Alloy Wheel Set (4) All
Celica '93 Monte Carlo Body Shell & Spare J Parts
Proline Hummer H1 Body Shell - Black Metallic, Tints & light blanks
005598 Taisan Starcard Porsche B Parts (Rear gear case)
005598 Taisan Starcard Porsche B Parts (Rear gear case) Incomplete
op37 53037 Hi Cap Dampers (Short) (NIP)
op37 53037 Hi Cap Dampers (Short) (Partially Built)
op54 53054 Hi Cap Dampers (Short) Spring Set
op70 53070 Manta Ray Ball Diff set TA01, TA02
op71 53071 Manta Ray Torque Splitter Set TA01, TA02
op79 53079 Manta Ray Stainless Steel Propshaft Set (NIP) TA01
op79 53079 Manta Ray Stainless Steel Propshaft Set New, no pack TA01
op99 53099 FRP Chassis Set - possibly complete TA01
FRP Chassis Set - used TA01
FRP Chassis Set - built TA02
FRP Chassis Set - used TA02
op109 53109 Turnbuckle Shaft Set
op127 53127 Skyline Speed Tuned Gear Set TA01, TA02
op141 53141 4WD Touring & Rally Car Lightweight King Pins TL,TA,FF,M09,M04
op142 53142 4WD Touring & Rally Car Aluminium Motor Mount (NIP) TA
op142 53142 4WD Touring & Rally Car Aluminium Motor Mount (New partial package) TA
op142 53142 4WD Touring & Rally Car Aluminium Motor Mount (New? no package) TA
op142 53142 4WD Touring & Rally Car Aluminium Motor Mount (Used) TA
op145 53145 Touring & Rally Car Urethane Bumper Set TA01, TA02
op152 53152 Short Type Hard Propshaft TA02
op152 53152 Short Type Hard Propshaft (Used) TA02
op155 53155 Low Friction Aluminium Damper Set, 4WD/FWD Touring & Rally Car
op164 53164 Touring & Rally Car Hollow Carbon Gear Shaft Set TA01, TA02
op191 53191 4WD/FWD Touring & Rally Car Turnbuckle Tie Rod Set TA,FF
op192 53192 4WD/FWD Touring & Rally Car Turnbuckle Upper Arm Set
op194 53194 Touring & Rally Car FRP Rear Damper Stay TA01, TA02
op200 53200 One Way Front Diff Manta Ray TA01, TA02
op218 53218 Touring & Rally Car Hard Joint Cup Set (Gear Diff) TA01, TA02
op225 53225 Touring Front Universal Shaft Set (Inc. Hummer) (NIP) TA02W
op225 53225 Touring Front Universal Shaft Set (Inc. Hummer) (Opened pack) TA02W
op225 53225 Touring Front Universal Shaft Set (Inc. Hummer) (Used) TA02W
op226 53226 Touring & Rally Car Aluminium Front Hub Carrier TA01, TA02
op244 53244 TGX Carbon Propshaft (TA01) TGX, TA01
op252 53252 TGX Rear Aluminium Upright Set
op303 53303 TL01 Adjustable Upper Arm Set TL,FF,WR02, Stadium Raider
op390 53390 Hollow Carbon Gear Shaft Set M03, M04, FF
sp336 50336 Thunder Shot Drive Shaft
sp336 50336 Thunder Shot Drive Shaft (Used)
sp603 50603 TGX (TA01) Stainless Steel Propshaft Set NIP TGX, TA01
sp603 50603 TGX (TA01) Stainless Steel Propshaft Set New, no pack TGX, TA01
sp883 50883 Drive Shaft 39mm
Aluminium Front Knuckle Set (No Packaging) TA01, TA02
49244 Aluminium Ball Nuts (blue) 5mm Pk.10 All
50646 Touring & Rally Car D Parts Set (Arms & Body Supports)
AR Products TA-18 Aluminium Propshaft (NIP) TA01
AR Products TA-18 Aluminium Propshaft (used) TA01
KOSE K1101 Hard Jiont Cup Set TA01, TA02
KOSE K1960 Front Adjustable Camber Set - All touring cars
KOSE x1907 Super Steering Set - All touring cars with stock chassis
KOSE K1904B Aluminium Servo Mount (blue)
CROSS TR19 Steering Set (TR-15F-R) TA01, TA02
GPM MT030 Aluminium Rear Damper Stay (red) Celica TA01, TA02
GPM TA1110 Front Stabilizer Complete Set TA01, TA02
GPM TA1022 Aluminium Rear Knuckle Set (blue) TA01, TA02
GPM Aluminium Front Damper Stay (Silver) Celica TA01, TA02
GPM TA3241 Alloy Universal Shafts (blue) 41mm
GPM MD049 Alloy Steering Plate (3x6mm bearings) Gold Manta Ray TA01, TA02
GRAUPNER TA1028 Alumunium Front Damper Stay (w.collars) Blue TA01, TA02
