Hi,
I've attached my servos to my MFC01 unit. But when I switch on the device from the control panel servos start to rotate without any command from the transmitter. Any advice?
Thanks, Meisam.
Hi,
I had a similar problem when I installed the MFC01 ino my King Hauler, except my servo's didn't work! Mine was easily cured by pulling the servo leads out the MFU, and turning them round. Might be worth a try, as it sounds like the servo wires are in to wrong order going into the MFU, if you get what I mean.
I'm using Futaba servo's, and radio gear.
Hope this helps :D
Hi,
Hope this helps :D
Thanks for your reply. I'm assemblying scania r470. What is MFU?
It`s the Multi Function Unit = MFC-01 or MFC -02 for the Hilux/F350
and yes,check the wiring,it does sound like something plugged in the wrong way round or similar.
Which cables? from servos to MFC or from MFC to the receiver?
I've just tried to adjust the MFC unit. after I press SW1 button on the MFC unit the light on the control panel starts to blink and it does not stop. That means I cannot continue with adjusting the unit.
Check all the plugs are correct or post some pics would be best so we can see :)
Thanks a lot for your help. The servos are working fine now. But I got a new problem: The steering rod touches the fender!!! :D
