Thanks in advance...
The radio box / tub is different too .Where the wires come through the box towards the battery , if the hole is a small oval then its Bruiser , if it is a larger squarer hole it is Mounty - the boxes are stamped as 'Toyota Mountain' and 'Toyota 4wd' .The battery shelf on the Mounty is edged all the way round to take a stick battery only,and the Bruiser shelf is open at the front to allow for the larger 4000mah battery set up I have 2 different types of chassis front beam and motor mount on my Bruiser and Mounty , namely the amount of stamped holes in the base if the mount and stampings on the front beam to match up with the mount .The wheels are one piece on the Mounty and split rims ( outer and inner ) on the Bruiser
Sorry can't help with which one it is but would be interested if its forsale?
dazaa
I was just about to say that <_<
