Does anyone know if the Super Fighter G body will fit on a Manta Ray chassis, the mounting points look about right, and it looks like the S.F.G. body will clear the manta diff and front shock tower ok. I know the DT-02 chassis is 5.5" wide at it's widest point which is the same for Top Force FRP chassis, so width shouldn't be and issue as long as I go with a FRP chassis.
What I really need to know is the distance between the centers of the front to the rear body mount posts and the amount of hight difference between where the body sits on the post front and rear. I know the DF-01 chassis of the Manta Ray is 9mm longer in the wheel base than the DT-02 chassis, but the difference is probably in the suspension arms not the chassis, I can shorten the FRP chassis plates to make the spacing of the body posts correct if need be, but I'm hoping to avoid that as in means a lot of work to get the prop shaft the right lenght.
Anyway if anyone has both cars, and can test fit the Super Fighter G body on the Manta Ray chassis, or can just meassure the spacing of the body post on one or more of the these cars that would be great.
