Does anyone know if it would be possible to use the M03 stabilizer set if the M03 chassis has GPM aluminum suspension arms installed?
Thanks in advance
The M03 stock arms are held together with 2 screws. This is also the mounting point for the stabilizers. If you've got additional mounting points on the GPM arms then it might work. If they're solid then you're going to have to drill and tap threads.
