I've got a Jugg 1 with knackered bevel gears. I know that Tamiya issued the "care-package" to replace these and quickly discontinued the Jugg 1 and released the Jugg 2 with upgraded bits. I also know that the fix-it packs are impossible to find.
Are there any bits currently available that can be used to fix the problem? or should I take it outside and shoot it?
Cheers.
TXT-1 axles are almost identical (the axle top casing is different as it has link mounts molded into it and the output shaft for the universal joints are 1mm wider)
Out of the 3 trucks that used those parts, its the only one still in production.
You'll need the axle case, and all bevel gears and shafts in the axle top. As far as I know, the differential is the same in the jugg1.
It might be worth looking for new old stock jugg2 parts as they will swap right over.
