Brettos 0 Posted May 5, 2009 I have a Tamiya Boomerang and i wan't to put shorter shocks on it. At the moment they are about 100mm long, this gives me 35mm ground clearance. I want to replace the existing shocks with 90-95mm long shock's, that will drop the rear end to 20mm ground clearance and lower my centre of gravity. Any thoughts on shock types around that length? Cheers, Brett. Share this post Link to post Share on other sites
HunterZero 76 Posted May 5, 2009 Removing any spring pre-tensioners or adding o-rings inside the damper bodies not going to work for you? - James Share this post Link to post Share on other sites
Brettos 0 Posted May 5, 2009 Removing any spring pre-tensioners or adding o-rings inside the damper bodies not going to work for you?- James Thanks James, Thinkin' outside the box! will let you know! Cheers, brett. Share this post Link to post Share on other sites
94eg! 834 Posted May 5, 2009 Thanks James,Thinkin' outside the box! will let you know! Cheers, brett. Actually those parts are included inside the box... Share this post Link to post Share on other sites
