I'm just after a bit of advice. My receiver aerila has snapped in a couple of places and although I've managed to repair it by twisting the wire togethr I don't want to do it again.
However, it's very difficult to thread it through the plastic tube - sometimes it just doesn't want to go. Any tips for getting it through the tube or how to prevent twisting and snapping of the little black wire?
If you have got a low wattage soldering iron, but dont fancy opening up the Receiver just solder a fresh piece of wire onto the original wire. Leaving say about 3-4 inches of the original wire.
Have done this recently on a minature Hitec 40mhz rx, that I couldnt take apart.
The wire must be the same gauge and the exact same length as the old one. Even then you may still see a loss in range or some glitching. Best to get a new appropriate length wire and solder directly inside the reciever.
How do you keep snapping the wire? I have yet to break a wire no matter how many crashes that have folded the tube right over. Many tubes, but no wires yet.
Yes indeed.
And somewhere on TC is a calculator for working out the length required.
The wire I use is 6 core alarm wire, never caused me any grief.
