post-6014-1249206342_thumb.jpgpost-6014-1249205310_thumb.jpgpost-6014-1249205656_thumb.jpgpost-6014-1249205198_thumb.jpg
Just a few pictures of my TT01 M-Chassis conversion. Currently running the wheelbase at 225mm to fit the Swift body. Equipped with full bearings, 3racing propshaft, shocks & graphite shock tower stiffeners. Motor is 15X2 Team Orion. Tyres are M-Chassis 60D type A on the rear & S grips on the front. Goes very well, really nimble compared to the original TT01. I would highly recommend this conversion to anyone who wants to revive a tired TT01.
  • 4 months later...
Hi,
Just bought one of these conversion kits as I wanted a 4 wheel drive mini. I'm having major suspension binding issues, anyone else having this problem ? I've tried shortening the upper arms pins but this hasn't sorted the problem out. Anyone got a solution ? Also, I noticed that building the arms as per the manual has them out of line with the dogbones, therefore they have had to be fitted the opposite way round.
I also had the wheelbase problem, and I've fitted aTtamiya Mini shell which has the front wheels a bit too far forward.
When I get it finished, I'll post some pics. Thanks for your help.
Regards,
32819toon
These look great,a bit like the ABC Genetic chassis.Does anyone have both? and maybe some comparisons,thoughts etc please :)
Keep the piccys,reports,[Video?] etc coming,all interesting stuff.
Cheers.
T.
Hi,
Regards,
32819toon
Just a thought, the steering is also very tight, I've used standard TT01 front knuckles, should I be using M03 ones ???
Update -
The root of the problem has been found. Whilst building up the kit, I put M03 universal driveshafts inplace of the kit dogbones. They turned out to be a little too long. When I fitted the dogbones, the suspension was fine with no binding. Problem solved !!
