hi all
ive just bought a traxxas evx-2
ive got a problem in getting it to run my crawler with 2 silver cans???
any ideas where im going wrong?
all i get is like a click/thud from the motors!! motors spin with battery so there not broken.
ive got the setup correct,,,powers going thru but not turning the motors,,,ive checked it with multimeter and power is there
im running 2x 8.4v 3300 mah freshly charged,and traxxas 3servo radio system
please help someone!!
thanks nic tt
hi
its still doing the same
ive tried it 3 times,,no difference at all
just done voltage check
1 say`s +19.49v
2 say`s -19.43v
are these correct?
was told this was brand new!off ebay and collected in person
thanks nic tt
hi
1 say`s +19.49v
2 say`s -19.43v
are these correct?
thanks nic tt
19.5 volts on a silvercan? :lol: Not positive, but I don't think a silvercan would like that much voltage. Rated for 7.2 volts and will run slightly faster on 8.4 volts, but will shorten it's life. Motors are probably seizing up on that much voltage. The Evx-2 is meant to power a pair of 21 turn Titan 550's rated for 16.8 volts like in the 1/10 E-Maxx. These motors also come in normal and reverse rotation for dual setups.
hi
thanks for that bit of info
i have checked it on my 550 cosmo winch with 148:1 ratio and that works!!!
it seams that the evx-2 wont work on 540 motors!!!
now im after 550 motor,,,any body got any???any condition but must be working
thanks nic tt
It will run 540 motors down to 10 turns, but the motors must be rated for the voltage. Click me for specs. The only motors that I know of with this rating are the 21 turn (not 12 turn) Titan 550's. New these sell for about $20 USD from Tower Hobbies and could probably be found cheaper on ebay. These will produce massive torque and speed since they are designed to run a 7 pound w/o batteries monster truck to 30+ mph.
hi
my silver cans are standard tamiya ones and think there only 7.2v-8.4v rated
think i need 2x 12v 550 motors,,,but not 100% sure
