I have a 1:5 scale H2 hummer im building at the mo and have hit a brick wall.
i have used Tl01 front and rear differentials (cut away the plastic chassis and mounted them to a custom
aluminium notched chassis) and have uprated all the suspension with extended aluminium
arms and custom aluminium dogbones,
i have removed the shaft that transfers the drive from rear to front and replaced it with universal joints
in expectation of building a raised transfer case for better ground clearance,
but need some recommendations on what gearbox or parts to use for the transfer etc.
it is running on MOAB 60 series off road tyres and i want to use the high performance motor i got with
the Tl01 chassis
