I've purchased the hub part tree for a Suzuki Swift M03M as I was told the steering arms were better than the original ones I had (and snapped) on my M03 Mini Racing. Problem is the bearings don't fit. I've checked the online manual and it says they use 1050 bearings, which are the same as my M03 (I know they are not 1150's in my M03 as I tried to swap one out of my M05 and it definately won't fit).
So, the question, did M03M's ever use 950 bearings? I haven't got any to try but I think that's the only sort that are going to fit.
No the M03M doesn't use a 950 bearing, but its hubs use smaller bearings then the M03. Hub bearings for the FWD minis go something like this...
M03 = 1150
M03R = 1050
M03M = 1050
M05 = 1150
M05 Pro = 1150 Front / 1050 Rear (Uses M03R rear hubs just for confussion)
IIRC you'll need some TA04 king pins (50882) too. The Racing Cooper has a completely different C Hub to that found on the M03M kits.
