I dont think those will fit your hound, they are the narrow front tyres for 2 wheel drive buggies. If you like that tyres though look at the Dirt hog 1 they are designed to fit, I just ordered a set today.
I have a set of these tyres (also purchased from tower)for my Rising Storm. They fit fine - you do need to glue them though, unlike the stock tyres that come with the Storm / Hound.
For some reason the foam inserts (which are supplied with the tyres) which i received were designed for the Dirt Hawg I, ie were too wide. Hardly difficult to cut them to size though - If I can do it I'm sure you can!
Phiber is right about the Dirt Hawg I's - perfect as rear tyres, but do need glueing.
I ordered a set of the narrows for the front coz i dint want the extra weight messing with my punch. but for the rear i ordered the wider ones. I ll reply when i receive them and try them on.
My front wheels are just the standard tamiya ones with the desert gator... They havn't worn at all. Sry for the slow responce, just back from a wee holiday... if you still want photos, let me know ill post them asap
http://i16.photobucket.com/albums/b20/pork13/HPIM0994.jpg
out of topic but cool thow
Finally got them
they fit exactly but i think the gront were ment for 2wd coz the diameter is a little smaller than the rear. the diference is 2mm.
I know is a very small diference but if it was bigger then that would be a problem coz the buggy doesnt have a central diff. and the speed of the front and rear tires must be the same.
ps i think the front would fit better in a 1 inch rim than in a 1.1/4 that is mine. but as you can see its fine
as for performance : i run a speed gems 17T motor with the
traxxas xl-1 esc and the grip is perfect in asphalt/pavement(it sticks like glue).its a preety powerfull motor and with 16/70 gearing it doesnt slips anywhere.
I dont think my esc will survive any longer . i think its going to melt or burn or both. its on its limits with a 6cell and i use a 7cell
I didnt try this on gravel or dirt or grass yet.
With these tire/wheel combos, how do they go on a harder surface such as ashphalt? With better clearance do you do many jumps? Has anyone tried slicks, and if so what brand and specs? Do they rub?
I dont see much nice gravel. But some of these seem cool for a bit of bashing around the traps here and there.
