The TZ and BZ are the same. Tamiya even tried changing the units of measure on the performance specs to disguise it. If you convert the BZ's 49mN.m, you'll see it's the same 500g/cm as the TZ. The main reason for the price bump was because they added the little foam covers for off-road (which are useless anyways)... Main difference between TZ and RZ is that the TZ has standup brushes and the RZ has laydown brushes. The laydown brushes increase the timing of the motor thereby incr
