TamiyaUSA updated their info on the F60!
Kit #58447:
http://www.tamiyausa.com/product/item.php?product-id=58447
Body Set #51397
http://www.tamiyausa.com/product/item.php?product-id=51397
Wheels for the rubber tires #54201:
http://www.tamiyausa.com/product/item.php?product-id=54201
Rear rubber tires #51400
http://www.tamiyausa.com/product/item.php?product-id=51400
Front rubber tires #51399
http://www.tamiyausa.com/product/item.php?product-id=51399
PS F60 Red paint #89922:
http://www.tamiyausa.com/product/item.php?product-id=89922
Quoted text:
Tamiya has a new edition to the 1/10 scale R/C F104 Series line up, an Officially Licensed 2009 season Ferrari F60. In the 2009 F1 season, Ferrari released the new F60 vehicle to celebrate 60 years of competition. The new F1 Ferrari debuted at the Australian Grand Prix. The F60 started off the season slow, but has gone on to win first place at Round 4 and scored points in every race since. The F60 has taken three 3rd place finishes, one 2nd place finish and a 1st place win at the Belgian Grand Prix. After 12 races, Ferrari holds the third position in the Constructors standings.
Specs & Features
This is an OFFICIALLY LICENSED 1/10 scale R/C assembly kit of the Ferrari F60 F-1 Car.
The kit features 3-dimensional front and rear wings, rear diffuser, side mirrors, and aerofoil suspension arms for enhanced realism.
New rubber tires and wheels enhance the scale realism of the F60. (4pcs.)
Body can be assembled with or without the polycarbonate sloped side pontoons.
Finish the body with Item 89922 PS F60 Ferrari Red).
TEU-104BK ESC and Type-540 motor included.
2-channel R/C system, battery pack & charger are separately required.
The F104 chassis features the same component layout as the F104 PRO and can be upgraded to F104 PRO standards with separately available Option Parts.
The F60 features the following new parts:
3.2mm thick FRP lower deck.
2mm thick FRP upper deck.
Stainless steel rear shaft.
Wheel base parts.
H Parts (Rear wing).
J Parts (Front wing).
A wide variety of Option Parts are separately available to further customize your F104
Item 84058 F104 Titanium Screw Set (Limited Edition R/C Parts)
Item 54159 F104 Aluminum Horn for Hi-Torque Servo Saver
Item 54165 F104 Soft T-bar
Item 54166 F104 Aluminum Motor Mount (Right & Left)
Item 54167 F104 Sponge Tires B (4430, Front, Standard)
Item 54168 F104 Sponge Tires B (4435, Rear, Standard)
Item 54169 F104 Aluminum Pivot Post.
Item 54176 Formula-Tuned Motor (32T).
Comparison with F104 and F104 PRO Chassis
F104 chassis F104PRO chassis
FRP upper and lower decks Carbon upper and lower decks
Stainless rear shaft Carbon rear shaft
Resin diff. housing Aluminum diff. housing
Friction damper TRF Special Damper
Quite a pity the Ferrari F60 is not on the 'Pro,' but it does look like a very nice spec car and release anyway! It's really amazing to see Tamiya actually went through the effort of official licensing for this car - Ok, I know there were so many F1 releases through the years, but an awful lot has changed in the past few years in the F1, and besides the licensing the detail is very hard to make!
Looks great except for the wheels.
Luckily the wheel spats on the front can be removed (at least, you should be able to), and with a bit of luck the rear wheels use covers and a normal wheel is behind the 'cover.' :)
Edit: http://www.tamiyausa.com/product/item.php?product-id=54201 These are four wheels, two of them looking slightly wider. No wheel covers needed on the rear either if you don't like them, in that case ;)
They remove themselves on Renault version released later in the year LOL
... impressive detail. but how did they mount the front brake cooling duct?
I want one.
I'm guessing they are like the 3Racing wheel spats that are available for this kit already. They replace the 4mm locking nut and since they clamp down on a bearing, they won't spin. The rears are supposed to spin. And, yes, I hope they are regular rims underneath the spats!
The pictures look fantastic! Count me in for at least 2 kits! LOL Maybe even 4. I'll want to build up a Raikkonen, Massa, Fisichella, and Badoer haha! I just wish it included Marlboro bar codes!
